Configure individual system-level switch parameters to configure global options for the switch.
    enable
    configure terminal
  2. Change the system name:
    sys name WORD<0–255>
  3. Enable support for Jumbo frames:
    sys mtu <1522-9600>
  4. Enable the User Datagram Protocol (UDP) checksum calculation:
    udp checksum
Switch:1> enable
Switch:1# configure terminal
Configure the system, or root level, prompt name for the switch:
Switch:1(config)# sys name Floor3Lab2
The following table defines parameters for the sys command.
Variable
Value
control tcp-timestamp
Enables or disables TCP Timestamp.
force-msg
Adds forced message control pattern.
WORD<4–4> Enter force message pattern.
msg-control
Configures system message control feature.
mtu <1522-9600>
Configures Jumbo frame support for the data path. The value can be either 1522, 1950 (default), or 9600 bytes.
name WORD<0–255>
Configures the system, or root level, prompt name for the switch.
WORD<0–255> is an ASCII string from 0–255 characters (for example, LabSC7 or Closet4).
power
Enables power to specified slot(s).
security-console
Enables the security console.
software
Configures software configuration.
priv-exec-password
Enables authentication for the Privileged EXEC CLI command mode.
